White Tie - IMPERIAL
Imperial 是由 REAPER 开发者之一 👤White Tie 设计的一款自定义主题。
可以在官方维护页查看图片预览:
White Tie : Imperial - REAPER theme for large monitors
Imperial's mixer needs to be undocked and maximised; if you only have one screen then flip back and forth to the mixer using CTRL+M. A large range of mixer layouts are provided - several for visual grouping, and three with focussed functionality and reduced controls for specialised workflow.
http://www.houseofwhitetie.com/reaper/imperial/wt_imperial.html
该主题设计用于 REAPER 5.x 版本,6.x 版本兼容可用。
前置需求
建议设置
为最适配本主题,以下为作者给出的建议设置:
In: Options > Preferences > Appearance
Tint track panel backgrounds should be unticked
Track grouping indicators should be set to 'Lines on edge'
获取地址
注意事项
